I'm not too sure if this is the right forum to ask. I've been having a problem with my office's network printer after the windows 10 update.
I have a Zebra Z4M plus DT label printer.
It is hooked up to a workstation via USB with no wifi capabilities. Other workstations print with that printer as a network. After the window 10 update, the driver disappeared on the other workstations. I managed to get it back, however every time I print, even with the dimension (4x6) selected, it is always out of place. The whole thing would be bigger and then the right and bottom margins are completely gone. However the workstation with the printer hooked up via USB prints with no problem. Is there any solution to this, as Zebra no longer support this printer.
Thank you in advance
