Question ZEN4 7700x ECO MODE NOT WORKING! lower temps undervolting? need HELP
May 13, 2022
4
Hi all,
nice to meet you. i hope this is the correct forum.
MOBO : ASUS X670e EXTREME
CPU: Zen4 7700x!
i am trying to lower TEMPS by 20 degrees. i have tried to enable AMD ECO MODE but it doesn't work. i tried all ways. 1: Ryzen Master NO REsult 2: BIOS AMD ECO MODE No Result. 3: BIOS MANUAL SETTING PBO NO RESULT!
Minimum temp with ASUS RYUJIN II is 70 degrees
in RYZEN MASTER i have put these values manually (don't know how good they are)
Volt: 1.25 isntead of 1.35 and CPU clock Speed: 4.2 GHZ instead of 4.5
still, the temps are higt at minimum 55 degrees!
Questions: what can i do to achieve less than 50 degrees STABLE with sacrificing the least perfomance.
am in in dagner of destroying my CPU with the above settings?
Any suggestions to lower temps?
Hi all,
CPU: Zen4 7700x!
"70 degrees minimum" is this this at idle or under load? If so, what load?
