zone games XP pro problem
Phil
838
Archived from groups: microsoft.public.games.zone (More info?)
I've just put XP pro over my win 98 SE (ok, maybe I should have done a clean
install, but I didn't).
Everything is working fine, apart from zone.
If i go to backgammon (or any other), it tells me i need to download and
install the latest files, brings up the warning box which i accept, and then
it fails - I've turned off my zone alarm but it has made no difference. I'm
logged on as administrator.
I uninstalled (from add/remove panel) what zone files I had - anyone got any
suggestions? ( i don't fancy deleting things out of the registry!)
Open Internet Properties, General tab, Settings button, View Objects
button. If HeartbeatCtrl, or ZoneIntro Class is listed as Damaged,
right-click, click Update to repair the ActiveX component.
+Elmo_Tech
MSN® Gaming Zone™ - Technical Support
Thanks for trying, but hasn't worked- they were both there fine, but updated
the Zone intro anyhow. Is it worth deleting them?
Thanks
Phil
> Thanks
> Phil
Here's the NibblesNbits site. Try this download page for help:
http://www3.sympatico.ca/nibblesnbits/EnterRooms.html#ftd
The new XP firewall supplied with SP2 could be the problem:
Known issues with XP SP2 and various products out there.
http://support.microsoft.com/default.aspx?kbid=842242
It may help to use the "Enabling programs" section of the above article
to allow Zone.exe, Zproxy.exe and any other Zone program that
communicates with the Zone.
There's a section here on disabling the XP firewall:
http://mvps.org/nibblesnbits/MultiPlayer.html#fwall
+Elmo_Tech
Will try those next week and report back - am away from computer with prob
at mo - i'm only on SP1 - did not put SP2 on due to what i've heard about
it.
> it.
Look in C:\Windows\Downloaded Program Files folder in a DOS window. In
DOS window, type:
CD C:\windows\downlo~1 (Enter key)
DIR (Enter key)
See if there are any \Conflict.xxx folders.
+Elmo_Tech
Hello
I am was having problems getting into the Zone's game room like (Backgammon)
with a windows XP system with sp2 installed, It's taken me afew weeks to
figure out why and how to fix it! I'm here to share what I have to do when
the problem accrues. First I'm using Window XP with SP2 for web
browsers I use MSN Premium Software, plus I'm using Internet Explorer
Ver:6.0.2900 with SP2_rtm I've had the same problem using both
browsers, The New Security of the SP2 and WinXp are the best yet.. This
is what I was told to do, to get the Game Rooms in the zone to open,
When it happens Hit your START BUTTON, Then go to RUN TYPE REGEDIT
Then Hit OK , The window that opens up, PLEASE NOTE DON"T DELETE
ANYTHING! Unless you know what it is.. FINE HKEY_LOCAL_MACHINE Then
in that File find SOFTWARE then scroll down till you find another File
named MICROSOFT, Then Scroll down to INTERNET GAMING ZONE, Then Find
ROOM, find the Zone name You are using, then Click the name.. ON the
RIGHT side there should be The Room or Rooms you have played in.. Find the
one you are trying to enter, then touch it with your Mouse pointer It
should turn Blue! Then You hit the Delete button on your keyboard,, Hit
YES when it asks you if you are sue you want to delete the file,, After
you've done that Close out the REGISTRY EDITOR Then try to enter the ROOM
you wanted to enter but couldn't,, You should be able to enter the room
without any problems, That problem may happen many times and you may
need to repeat this each time,, To give anyone some peace of mind about
this,, The Security of the Zone and Microsoft are there to keep us safe and
to keep our Systems Hacker free.. This is a Small price to pay! Please
Enjoy the ZONE,, Thank you for listing!
Phil" <spamspam@nospambtinternet.comspame> wrote in message
news:33e89pF40n0h6U1@individual.net...
> clean
> then
> I'm
> any
Mel Hockley Jr wrote:
> Hello
> I was having problems getting into the Zone's game room like (Backgammon)
> with a windows XP system with sp2 installed, It's taken me a few weeks to
> the problem occurs. First I'm using Window XP with SP2. For web
> browsers, I use MSN Premium Software, plus I'm using Internet Explorer
> Ver:6.0.2900 with SP2_rtm. I've had the same problem using both
> browsers. The New Security of the SP2 and WinXp are the best yet.. This
> When it happens Hit your START button, then go to RUN, type REGEDIT
> Then Hit OK. The window that opens up, PLEASE NOTE DON"T DELETE
> ANYTHING! Unless you know what it is.. Find HKEY_LOCAL_MACHINE
Click the + sign to the left of each of these to expand them.
> Then
> in that Folder find SOFTWARE, scroll down till you find another Folder
> named MICROSOFT, scroll down to INTERNET GAMING ZONE. Then Find
> ROOM, find the Zone name you are using, then Click the name.. ON the
> one you are trying to enter, then click it with your Mouse pointer It
> should turn Blue! Then You hit the Delete button on your keyboard, Hit
> YES when it asks you if you are sue you want to delete the file. > After you've done that Close out the REGISTRY EDITOR Then try to enter the ROOM
> you wanted to enter but couldn't. You should be able to enter the room
> without any problems. That problem may happen many times and you may
> need to repeat this each time.
Is that the problem where the room flashes open, then closes? Perhaps
it's similar, but has changed due to the added dialogue when checking
for updated files. If so, this was a problem before SP2.
There's a REG file available at
http://www3.sympatico.ca/nibblesnbits/EnterRooms.html that might make it
easier; you leave it on the desktop, or wherever is convenient, and
double-click it whenever there's a problem entering a room.
Add clvck to the subject line and correct my address from "invalid" to
"com" if you want to email me.
+Elmo_Tech
> > it.
> DOS window, type:
> DIR (Enter key)
I have 8 conflict folders - so what should i do with these? thanks..
Hopefully I'll be back on zone soon - i've downloaded the regisry patch but
this hasn't worked.
Phil
Phil wrote:
> > > it.
> > DOS window, type:
> > DIR (Enter key)
> this hasn't worked.
> Phil
Conflict folders aren't always bad.. For the next step, let's look in
the folders and see what's in them:
- Open a DOS window.
- Type
CD C:\Windows\Downlo~1
DIR
- Look at the extensions of the folders.. They may be 1 or 001, e.g..
Type:
CD conflict.1
DIR
- Look in the folder and see what's listed.
Type CD..
CD conflict.2 (or whatever the next folder extension)
DIR
- See what files are listed. Continue the above till you've checked out
all the folders. If all of them contain ZINTRO.OCX then open regedit.
- Do a search (F3) for \conflict When found:
1. Press Ctrl key and the + key on the numeric keypad. That will let
you see the complete path. Verify it has a Zone reference, then remove
the entry in this manner:
2. Press the Delete key; you will be prompted to delete it. Do so.
3. Press F3 to continue the search. If more are found, go back to 1.
above.
Try the Zone again with antivirus software turned off.
+Elmo_Tech
Elmo wrote:
> Phil wrote:
> > > > it.
> > > DOS window, type:
> > > DIR (Enter key)
> > this hasn't worked.
> > Phil
> - Type
> DIR
> Type:
> CD conflict.1
> DIR
> Type CD..
> DIR
> above.
To delete a Conflict folder:
- Type
DIR
DELTREE Conflict.* *.*
I think that will do it.. With XP, it may be different. If no-go, I'll
look up the commands for XP. I have a couple of files that might delete
the Conflict folders here:
http://members.iglou.com/elmogeek/
You can right-click the files, click Edit, or click Send To Wordpad if
you want to see what's in these batch files.
+Elmo_Tech
looked at the 1st 3 conflict files...all have zsetup, a few have heartbeat
in as well, so haven't looked thru the rest of them, but they don't have
zintro.ocx in.
thanks for the help so far, any other suggestions?
http://classic.zone.msn.com/down_zsetup.asp (full install) says wait for
page to load when i clicking on a lobby.
Phil
> zintro.ocx in.
> Phil
That error is discussed here in step #5:
PLEASE WAIT FOR PAGE TO DOWNLOAD
+Elmo_Tech
> > zintro.ocx in.
for
> > Phil
OK, that downloaded main zone files again, and logged me on to zone friends.
After rebooting, I cant get back on to friends though, and still get the
same errors when trying to download/go to a page with games on i.e. it comes
up with a box to download files, I click yes, but then says on the web page
unable to download.
Thanks for all the suggestions, but none seem to work, so looks like it's
thanks microsoft, but I'm stuffed - time to find online games somewhere
else.
Phil
Phil wrote:
> > > zintro.ocx in.
> for
> > > Phil
> unable to download.
> else.
> Phil
Don't have Passport log you on automatically; it doesn't log you onto
the Zone. Turn that option off and use the NibblesNbits script if you
want. I'm not sure that will help with your problem though, it's just
an idea.
+Elmo_Tech
> it easier; you leave it on the desktop, or wherever is convenient, and
FWIW, I had this flashing room problem for quite a while in backgammon, but
maybe 2-3 months ago it went away and I haven't ad the problem again..
XP-SP2. Perhaps the Zone updated something.
Gregg C.
