zotac 1050ti mini possible 6 pin connector
RYZEN_ATHLON_X
I've seen this before on other cards and wondered is i were to desolder a 6 pin pci e connector from another card and solder it to the PCB of the 1050ti mini and if the card would allow more power. There are a lot of other people wondering the same thing but theres no word from anyone that its works hopefully i can get some clarification and i might as well try it
TOP LEFT OF PCB http://tekeverything.com/wp-content/uploads/zotac-gtx-1050ti-back.jpg
that will most likely void the warrenty and you will probaly short the circuit bord and fry the card causing all kinds of problems. why do you even want to sodder an extra 6pin connector to your 1050ti?
i would like to see or know if this would work theres really no way of severely overclocking this card without using more than 75 watts
