The base 1070requires only a 500 watt PSU and a single * pin power connector. Cards tested by TPU have shown the ability to pull 220 watts but the Zotac AMP was not among those tested. With 75 watts from the PCIE slot, that leaves 145 to be supplied by the cables, and a single 8 pin connector will supply 150. And while I wouldn't argue against a 6 + 8 pin connector, the inclusion of an 8 + 8 is just marketing to make the card appear more powerful.
What Supernova are we talking about here.... It's kinda like asking what's the ignition timing on my Blue Chevy Impala
-The G2 Supernova provided 3 PCI cables: 2 x 8-Pin (6+2), 1 x 6-Pin PCIE .
So you should have more cables than you need if it's the G2
-The GS 550 has 4x 8pin (6+2), again more than you need
-The G3 500 provides 3 x 8pin (6+2) PCIE. more than you need
It must be said that the following statement, as written is incorrect.
"12V power all comes from the same place, it doesn't really matter where you get it from plug wise."
More correctly said ...
"On a single rail PSU , 12V power all comes from the same place, it doesn't really matter where you get it from plug wise."
Some PSUs have multiple rails and the individual loading
on each rail must be below that rail's rating., There are many who claim advantages of single rail versus multi rail designs but other than the above, the claims do not hold up to scrutiny. And many PSUs advertised as multi-rail are not so it can be confusing.
http://www.jonnyguru.com/forums/showthread.php?t=3990
In most cases, multiple +12V rails are actually just a single +12V source just split up into multiple +12V outputs
each with a limited output capability.
This is why splitters are always a bad idea. If the PSU is in fact multi rail, rather than just being advertised as such, you CAN overload one of the rails ... On a multi rail design, you might have say 15 watts on each rail. As designed, each PCI E cable will be on a separate rail .
An 8 pin could draw 150 watts or 12.50 watts on one rail
An 6 pin could draw 75 watts or 6.26 watts on one rail
Put them both on the same rail by using splitters or auxilliary connectors and you will soon be muttering "Houston we have a problem".
