Question ZOTAC 2070 Amp Extreme vs. ZOTAC 2080 Twin Fan
ODoyleRules
5
So I'm in the market for a new GPU and been eying the RTX 20 series, currently have a GTX 970 and really need to upgrade. Out of curiosity how much of a difference in performance, mainly FPS and GPU temps, would there be between the ZOTAC RTX 2070 AMP Extreme with a boost speed of 1860MHz and the ZOTAC RTX 2080 Twin Fan with a boost of 1710MHz? Obviously the 2070 has fewer CUDA cores but higher clock speeds and triple fans for cooling, where as the 2080 has more CUDA cores but a lower clock speed and only 2 fans. Which do you think would perform better under load? I stream and play on a single PC setup and am curious which would be more beneficial. I want to say the RTX 2080 should still perform better but the 2070 with a higher speed and presumably better thermals has me questioning that.
Similar threads
