T Trigger12.T Feb 25, 2019 13 1 15 Feb 25, 2019 #1 Would a Zotac GeForce GTX 1050Ti 4 GB OC Graphics Card fit in a Dell optiplex 790 ssf (Dimensions = 5.5 x 21.5 x 28 cm)
K King_V Illustrious Ambassador Nov 1, 2014 8,507 2,708 42,090 Feb 25, 2019 #2 No. That is a normal form factor video card. If your Optiplex 790 is a small form factor, you will need a low-profile GPU. Upvote 1 Downvote
T Trigger12.T Feb 25, 2019 13 1 15 Feb 25, 2019 #3 How about the Zotac NVIDIA GeForce GTX 1050Ti 4 GB LP Graphics Card it should have a changeable bracket for ssf cases Upvote 0 Downvote
alceryes Splendid Jun 11, 2004 4,620 1,128 28,090 Feb 25, 2019 #4 If it's a low profile (LP) card then it should fit. This is assuming that your power supply can handle it. OEM power supplies are notoriously low quality. Upvote 1 Downvote
