Zotac GeForce GTX 1070 Ti AMP Extreme Review
Man this whole TI crap is a gimmick. My ASUS Strix 1070 maxes out at 2100 and sits stable at 2050 to 2080 during gaming. I don't understand this at all.
At 529 it makes absolutely ZERO sense to buy a 1070 Ti. I bought my Strix 1080 OC a month ago for 549 after rebates. If NvIDIA were to price the Ti at 400 and drop the 1070 to 349-359 then the Ti would make sense. But when you can get a 1080 for 10-20 bucks more why would you get a Ti?
ZOTAC continues to be unable to create an efficient cooler or even setup a custom fan profile.
The GTX1070Ti is up to 10% slower than a similar GTX1080 (when the slower 1070Ti memory bottlenecks especially), and with the requirement to run the OC software at all times the 1070Ti only makes sense if the value is there.
You also need to consider that it's the TOTAL PC COST (including monitor, games too) you should be comparing to determine value as $50 more for a GTX1080 on a $2000 PC investment is 2.5% of the cost so if you get an average of 5% or more FPS gain it may be worth it.
What's NOT worth it is to spend almost the same or even more than the cost of a GTX1080 that performs better and may be QUIETER to boot.
Think first, then write...
The original review was published in German, weeks ago. And the gaming results are, to be honest, more or less secondary. To be comparable between all this 1070 Ti's we also need a frozen system to check each card under the same condtitions (I've tested so far six cards). And it is NOT a Vega vs. Ti review, but a tech analysis of a single VGA card. Not less and not more.
