Okay so I just got a motherboard (ASRock N68C-S UCC) and processor (AMD Phenom II X4 925) as well as the gtx 750 TI. I did a fresh install of Windows 7 X64 and installed the latest drivers from the zotac website. Now when I boot up the computer, instead of seeing the normal windows 7 animated logo it switches to a green loading bar then immediately turns the screen black with "no display" on the monitor. I've looked into it and some people suggest plugging in vga and disabling the onboard display. I've done that and nothing. I've changed the default display to pcie in the bios and pretty much done everything dozens of forums suggest but no luck. My power supply has an output of 450 watts so power shouldn't be an issue.
I've also installed .NET Framework prior to driver install.
