zotac gtx 1060 6Gb mini temps
vopinca9
So i have recently have built a new gaming rig its nothing special, but done a bit on the budget side my specs are:
Intel pentium g4600 @3.6 ghz
gigabyte h110m-a mobo
8gb hyper x fury ddr4 2133 memory
zotac geforce gtx 1060 6gb
cooler master t2 cpu cooler
500gb samsung 850 evo ssd
deep cool da 600 psu
BitFenix - Nova ATX Mid Tower Case
x3 lg 22'' ips led monitors
The question i have is, I only play assetto corsa and this pc was built as a racing sim and it always stays @95 fps or higher while playing on 5760x1080 on medium to normal settings. I am pushing this mini cardn to run 3 monitors and y concern is my card is reaching thermals all the way to 75 degrees Celsius under load @ stock frequencies. this is the hottest it ever gets and levels off at that. Is this where it should be at thermals wise or is this to high? I am running 2 120mm generic intake fans and the 1 stock 100mm exhaust fan just for reference. Can somebody more experienced give their thoughts on this asap?
I have that card and it runs hot too. It was running at 75-80 until I got a better case and liquid cooling for my CPU(I think the hot air being expelled directly out of the case helped temps inside the case)...now it runs at 65-70 max.
From what I understand, it's not really an issue at all unless your temps are going over 80c.
They do sell aftermarket GPU coolers if you are still worried about it. I was reading that quite a few people opt to install the aftermarket coolers on this card due to the stock cooler not being very good.
MERGED QUESTION
Question from vopinca9 : "zotac gtx 1060 6GB mini temps"
80 degrees Celsius is considered normal operating temperatures for that GPU
