evyosh Honorable Sep 11, 2015 309 0 10,860 Apr 24, 2017 #1 Will the Zotac GTX 1070 AMP! Extreme edition card fit in a NZXT Source 340 (S340) Mid Tower? is there anyone using this case, how is it?
Solution raisonjohn Apr 24, 2017 evyosh : Will the Zotac GTX 1070 AMP! Extreme edition card fit in a NZXT Source 340 (S340) Mid Tower? is there anyone using this case, how is it? It does. Here are some completed builds: Source: https://pcpartpicker.com/b/ptVYcf Source: https://pcpartpicker.com/b/hzMZxr Source: https://pcpartpicker.com/b/xNQZxr
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 Apr 24, 2017 #2 Short answer is yes Long answer GPU is 300mm GPU Clearance With Radiator: 334mm GPU Clearance Without Radiator: 364mm So yes it will fit. Upvote 1 Downvote
DRagor Polypheme Jan 23, 2017 9,098 813 65,440 Apr 24, 2017 #3 Actually, card length is 325mm https://www.zotac.com/product/graphics_card/zotac-geforce-gtx-1070-amp-extreme#spec so it would be really close with radiator. Upvote 1 Downvote
bignastyid Titan Moderator Jun 19, 2011 33,689 1,700 159,590 Apr 24, 2017 #4 DRagor : Actually, card length is 325mm https://www.zotac.com/product/graphics_card/zotac-geforce-gtx-1070-amp-extreme#spec so it would be really close with radiator. Guess thats what i get for look at the amp instead of the extreme oops. Upvote 1 Downvote
raisonjohn Expert Ambassador Feb 22, 2015 4,102 103 39,040 Apr 24, 2017 Solution #5 evyosh : Will the Zotac GTX 1070 AMP! Extreme edition card fit in a NZXT Source 340 (S340) Mid Tower? is there anyone using this case, how is it? It does. Here are some completed builds: Source: https://pcpartpicker.com/b/ptVYcf Source: https://pcpartpicker.com/b/hzMZxr Source: https://pcpartpicker.com/b/xNQZxr Upvote 0 Downvote Solution
evyosh Honorable Sep 11, 2015 309 0 10,860 Apr 24, 2017 #6 Thank you so much for all your quick answers bois... Upvote 0 Downvote
