escendol :
matthew4mckeever :
Seriously? Why are you complaning about 130fps? Why would you want anymore than that? I mean unless you have a 144hz monitor then it doesn't matter.
Also, the people who tested it are obviously going to get more FPS considering you have an i5 4690k (same as me) and they have a i7 6700k, which is overclocked...
im using 144hz monitor so yeahh, i know the difference between the i7 6700k and i5 4690k but i expect a bit more than that lol but thanks anyway
It's quite possible your CPU is bottlenecking your GPU, that's what was happening to me and I have a Zotac 1080 AE. I recently upgraded to a 6700K (From a 3770K) and now I can run everything perfectly fine, maxed out at 1440p. If you are not overclocking I would look into that, or getting a better CPU. 6700k is top of the line, you can do very well with an i5 6600K. Blizzard's optimization is extremely disappointing as well. I had to do a lot of tweaking just to get stable 60fps on WoW... and again I have a 1080. It is also quite possible it is the game and not your hardware. My experience with Blizzard that's what I would say.
