zotac gtx 1070 founders edition VS gigabyte gtx 1070 mini itx
I personally would go with one that has dual or triple fans and has the highest stock clock speeds that you can afford. The Founders Edition cards tend to run warmer and the fan is louder than the dual or triple fan cards. The mini versions typically only have a single fan that has to work harder (louder) to keep it properly cooled. So basically I can't recommend either. Look for something like a EVGA FTW card, or one of the MSI Twin Frozer cards.
Well if those are the only two cards you are considering I would go with the founders edition card. It likely has similar cooling performance as the mini ITX card, however gigabyte may have cut down the VRM to make the card so small. So if space is not an issue I would say the founders edition card is the better buy, especially since its cheaper.
I think ill go with the zotac
now 1 thing remaining and ive been struggling to get help with this hope you guys can help
whats the BEST z270 Board for 140 usd (170 cad)
I have a i5 7600k
those are the ones I found but dont know which one to go with:
ASRock Motherboard Z270 PRO4 123 USD
Gigabyte LGA1151 Intel Z270 2-Way Crossfire ATX DDR4 Motherboard (GA-Z270-HD3) 125 USD
ASUS PRIME Z270-P LGA1151 DDR4 HDMI DVI M.2 USB 3.0 Z270 ATX 159 USD
Gigabyte LGA1151 Intel Z270 2-Way Crossfire ATX DDR4 Motherboard (GA-Z270P-D3) 121 USD
MSI Z270 SLI SDRAM Motherboards 142 USD
Gigabyte LGA1151 Intel Z270 2-Way Crossfire ATX DDR4 Motherboard (GA-Z270M-D3H) 123 USD
