Question Zotac GTX 1080 ti blower thermal pads replacement?
joelmappa
189
Hello,
I bought a used zotac gtx 1080 ti blower edition and the thermal paste need to be replaced from the seller sayings.
https://www.zotac.com/us/product/graphics_card/zotac-geforce-gtx-1080-ti-blower
Based on the model I think I have to remove the whole heatsink to replace that paste.
Which brings me to my questions
Do I need to replace the thermal pads?
Is it necessary?
If yes,
would this model work|
https://www.aliexpress.com/item/100..._id=202403060842194914126762647050001242586_4
And what sizes do I exactly need for it and how many?
Do you think replacing it with thermal putty and removing the old thermal pads is worth it?
Repaste the gpu die. As for the rest, if it ain't broke, don't fix it.
Been running a Kraken G12 on my 1080Ti for just shy of 4 years, with nothing on the memory.
Not a hitch from it. Case air and the single fan are adequate.
