ZOTAC gtx 750 ti power requirements
THEkillerjoke
Commendable
Sep 3, 2016
52
Hi as I mentioned above..will the zotac 750 ti..(2gb ddr5) be compatible?? With this pc specs
The pc specs are
Intel i3 530 2.93 ghz
8gb ddr3 ram
500gb Seagate HDD
Win,7
Iball lps223-400(250w)
Why am I asking is I saw a video in which a 250w psu ran without a problem with Intel i3 4140(or something...) and the gtx 750 ti plz tell me thanks.
You have quality and size mixed up. Cards like the gtx 750 are for smaller wattage PSUs, not low quality PSUs. A garbage quality 750w PSU could still fry that system. A good quality 350W PSU would work just fine, probably even get away with a good 300w unit. Possible outcomes with your current psu include but are limited to the psu shutting down under load, psu failing and taking some to all of the other components with it, the PSU catching fire.
But some card a
But some cards are for low end PSU's like the gtx950(Asus,2g, white) and this one which does not require a 6or8 pin slot. Which card do u suggest for gaming in this psu??. I cant change it until it dies
Corsair/Cooler Master/EVGA all have plenty of low quality units, too.
There's a reason I provided a list of all PSUs arranged by quality, sir.
