HI to all I recently upgraded my rig from a GTX 580 to a Zotac GTX 780 Ti OC ; the below is my current rig setup;
Asus M5A99FX PRO / AMD FX-8350 / 16GB Corsair Vengeance / Zotac GTX 780 Ti OC / WD 2TB HD / WD 1TB HD/ LG 23" LG W2363D-PF / Seasonic 720/Cooler Master HAF X 942 / Windows 8.1 PRO.
So I swapped my 580 with the 780ti and booted up, everything went fine except for the fan speed which immediately went from 30% to 100% upon loading windows.
I decided to uninstall the nvidia driver, so I used Display Driver Uninstaller (DDU) in safe mode; (I also noticed that when booting in safe mode the fan remains at 30% and is not even audible,since the drivers are not loaded during windows safe mode.)
DDU detected the previous drivers for my GTX 580 and removed everything, rebooted to normal windows, fan speed remained at 30% downloaded the latest nvidia drivers 347.09.
As soon as the drivers where installed the fan speed throttled up to 100%; just like that.
I also noticed that in Geforce Experience under LED Visualizer the fan RPM is 0 meaning that the fan speed is not being detected.
I am really at a loss at what the problem could be, this is the first time that I have a card with three fans, could it be that there is something I am missing with regards to the Driver not detecting fan speed ?
I stuck the card where the 580 was previously, since my mainboard has three pci-e slots.
Any help is really appreciated, these fans are really loud at 100% and I am quite at a loss as to why this is happening..
I forgot to mention temps idle between 25 - 28 deg. I use Aida finalwire to monitor temps.
Thank you.
Thank you.
