Zotac GTX 970 AMP! Omega 91c at load with overclock?
H4Z3YYY
21
So I have increased the GPU to these clocks: http://i.gyazo.com/09cf1acee6606cf57912437268592793.png
And whenever I play GPU-demanding games I get a whopping temperature of 91c! It was 83c without the overclock (which many would still believe to be pretty high for a GTX 970) my questions are, what would possibly be causing this? I have a Corsair Graphite 230T case with its stock 3x fans and yes the cables are managed well enough for the airflow to come through nicely. I also have a Corsair CX 750 PSU (which I will upgrade next week on my payday) if that helps. All I really need is reassurance that this temp will not harm the GPU and that it does not exceed the maximum safe temperature of this GPU. Thanks in advance.
I've looked at RivaTuner while in game and I haven't seen it throttling down at all, and I'm pretty sure the fans run at max speed already when I'm playing games and this temp shows up.
So I set the temp limit to 80c on MSI Afterburner and BAM! Still a very stable overclock with the temp maxing at 80c
Thanks for your help anyway guys and I'm hoping to push the card to its limits once I get a good power supply :)
