[SOLVED] Zotac RTX 2070 Super AMP Fan Model Number
Feb 10, 2021
11
Hi there,
I'm literally kinda sad today because one of the fan of my Zotac RTX 2070 Super AMP started a very bad rattle sound after 2 hours of gaming or randomly in February! I sent it to Zotac RMA and they back my graphics card after 2 months without a solution. Here is the video:
View: https://www.youtube.com/watch?v=C-iFgraXn1E
Well since they back to my card without a solution, I need to fix it by my own or with a help of my friend, Can anyone guys tell me the exact model of the Fan(right side) of Zotac RTX 2070 Super AMP.
Here is my model: https://www.zotac.com/us/product/graphics_card/zotac-gaming-geforce-rtx-2070-super-amp
I know I can pull of my fan and see the model number. But don't want to pull it ow, So anyone know about the exact model number of the fan so I can order it?
Thank you!
11 bladed fans. The ones on the card are 9 blade. Looks like the real fans are semi-translucent.
These are a closer match:
Generally not that easy to find them by part number. Usually best to take the card name into Ebay or Amazon and look for replacement fans since the people selling them will rarely have the OEM parts.
Just match up the wiring and fan shape, usually work fine. Which means taking it apart anyway, you might as well.
@Eximo , Man! You just saved my money! I am so blind that I didnt noticed that one is 11 bladed. Thanks man! You saved me!
The last question, Since my right fan making a noise, so should I buy this one: https://prnt.sc/11w0v7d ?
or
This one: https://prnt.sc/11w0vl2 ?
Or I can purchase anyone of these since the cable may not matter in my problem. They all are detachable fully, right?
Really noob of this.
Thanks in advance for your help!
