omernasir35
Hey guys, I needed help. My 3D card mem temps used to go to 104-108 during mining while giving me 101 MH/s on ethhash. So I decided to replace the thermal pads on it to prolong its life, increase it's thermals and hopefully make it run quieter (fans used to be on 85%). So I got my thermalright Odyssey pads and I used 2 mm in the front and 3 mm on the back. But the thermals became way way worse than before starting to throttle at 110 degrees. So I tried replacing the back pads with 2mm as well but it didn't help. I have also applied conductonaut liquid metal on the gpu but the gpus temps were never the issue to start with. I am put of ideas as to why the thermals have gotten so bad. Any help would be greatly appreciated. Thanks a lot.
The pics of the thermal pads I applied
