Zt system sound card update
mablandino
Hello,
I needed to reformat my pc....(i had a mess)....all is good now, but i have no sound. ZT system says no audio device found.......how do i install/activate the sound chip hat came with the zt system?
Go into Computer -> Properties -> Device Manager and you should see a yellow triangle over the sound devices section. If not, go to File -> Scan for hardware changes and then it will find it and have it automatically search for drivers.
If that doesn't work, and if your ZT came with a drivers disk put that in and install audio drivers. Otherwise, post the model number and I'll send the link for the right one.
