R Ricster-a Honorable Jan 19, 2014 133 0 10,680 May 15, 2014 #1 So i was told the vin1 voltage is too high in CPUID HWMONITOR can somebody tell me if my PC is healthy? and if not how do i change it.
Solution scout_03 May 16, 2014 compare your reading with this one on the sensor part they must be the same and you system look good to me http://www.hwinfo.com/download.php
hans_pcguy Distinguished Nov 13, 2010 584 1 19,160 May 16, 2014 #2 I get wrong results in monitor programs on a regular basis. I just ignore them. If you get a major discrepancy in your 12v or 5v rail check them with a multimeter. I would ignore the incorrect voltage reading that you are getting. Upvote 0 Downvote
scout_03 Titan Ambassador Feb 18, 2010 30,566 321 107,640 May 16, 2014 Solution #3 compare your reading with this one on the sensor part they must be the same and you system look good to me http://www.hwinfo.com/download.php Upvote 0 Downvote Solution
