I have a bunch of stuff on wired ethernet, wireless from the modem and a mesh (Deco). It works fine, until it doesn't. Then I wind up going back and forth between the switch and the mesh. When it fails, it usually hangs all of the wired Ethernet. It is very frustrating to determine which port of the main switch is causing or passing along the issue. The switch I currently have is a Netgear FS116. What should I buy that could give me an indication of which port is messed up?
Thanks
Thanks
