£500/600 For a new build - Help!
JamieIsOnline
5
I was looking to upgrade my pc but I was told I might as well just start from scratch.
I was planning to keep my case, disc drive, hard drive and I have a spare copy of windows 7 so those costs are cut.
I ideally want to run my DAW software smoothly and be able to play games at a decent speed
what can people recommend for that budget ?
cheers
Jamie
Using ebuyer.com for costs:
467647 Intel Core i5 4670K Retail Processor £186.63
389658 Crucial 16GB kit (8GBx2) DDR3 1600 £97.00
363095 OCZ 500W CoreXStream PSU £33.99
507058 Gigabyte GA-B85M-HD3 mATX Motherboard £61.72
525309 Gigabyte GTX 760 OC Windforce 2GB Graphics Card £219.00
With free delivery that would come to £598.34.
I chose 16Gb as you said you were using DAW software. It may be overkill. You could replace it with:
342352 Crucial 8GB (2x4GB) DDR3 1600Mhz Ballistix £50.00
which would then make the total: £551.34
