£589 first pc build (plus 144hz monitor)
Hugo Dodd
Hello guys,
(https://uk.pcpartpicker.com/list/W2crjc)
I have been researching into getting my first gaming Pc for a while and this is what I have come up with. Are there any changes you would make and will there be any performance bottlenecks?
Thanks in advance
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor (£63.47 @ BT Shop)
Motherboard: MSI - B250M PRO-VDH Micro ATX LGA1151 Motherboard (£64.97 @ Ebuyer)
Memory: Corsair - Vengeance LPX 16GB (2 x 8GB) DDR4-2400 Memory (£119.59 @ Aria PC)
Storage: Crucial - MX300 275GB 2.5" Solid State Drive (£79.99 @ Amazon UK)
Video Card: Zotac - GeForce GTX 1050 Ti 4GB Mini Video Card (£131.50 @ Amazon UK)
Case: Thermaltake - Versa H15 MicroATX Mid Tower Case (£31.95 @ Amazon UK)
Power Supply: Corsair - CXM 450W 80+ Bronze Certified Semi-Modular ATX Power Supply (£48.48 @ Ebuyer)
Operating System: Microsoft - Windows 10 Home OEM 64-bit
Other: Acer Predator GN246HL 24" Gaming 144Hz Monitor (£169.97 @ Ebuyer)
Total: £709.92
Generated by PCPartPicker 2017-07-25 20:50 BST+0100
G4560 is cheaper but only 4-5 % slower than i3
1050ti much better than rx 460 .
Ram is cheaper and faster ( Cas: 14) , also 2x dimms better than 4x
Also Psu is higher quality ( 450w are enough)
Motherboard: Asus - PRIME B250-PRO ATX LGA1151 Motherboard (£80.71 @ Aria PC)
Memory: G.Skill - Ripjaws 4 series 8GB (2 x 4GB) DDR4-2400 Memory (£59.30 @ Amazon UK)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive (£37.99 @ Aria PC)
Case: BitFenix - Nova ATX Mid Tower Case (£25.80 @ Aria PC)
Power Supply: XFX - XT 400W 80+ Bronze Certified ATX Power Supply (£34.99 @ Overclockers.co.uk)
Monitor: AOC - G2460PF 24.0" 1920x1080 144Hz Monitor (£209.98 @ PC World Business)
Total: £643.74
Generated by PCPartPicker 2017-07-25 21:09 BST+0100
Rather weak and will struggle to get to 144hz in most games, if you want a build capable of 144hz you should up the budget or get a 60hz monitor and get a minimum of i5 or R5 with a RX 580 or GTX 1060.
