Hi guys, names Adam. First time posting here. Hope everyone is okay
I'm planning on getting a second graphic card to supplement my rig, below is the set up that I purchased, do you think that a second card identical to the current one will be ok with the current power supply?
I believe there was a previous post staging 850w was acceptable but I just wanna make sure so my system doesn't explode in my face, lol. Thanks again.
BLUETOOTH: None
CARE1: Ultra Enhanced Packaging Solution - Protect Your Dream System During Transit
CARE2: Professional Wiring for All WIRING Inside The System Chassis - Minimize Cable Exposure, Maximize Airflow in Your System
CAS: * Cooler Master HAF-X Gaming Full Tower Case w/ 1x230mm Fan, 1x200mm Fans, 2xFront USB 3.0 Port
CASUPGRADE: None
CD: LG 12X Internal Blu-ray Drive & DVDRW, 3D Playback Combo Drive
CD2: None
COOLANT: Standard Coolant
CPU: Intel(R) Core™ i5-3570K 3.40 GHz 6MB Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FAN: Maximum 120MM Color Case Cooling Fans for your selected case
ENGRAVING: None
FA_HDD: None
FAN: Thermaltake Water 2.0 Pro Liquid Cooling System 120MM Radiator (Dual Standard 120MM Fans (Push-Pull)
FLASHMEDIA: None
FREEBIE_MB: GIGABYTE GC-WB300D Exclusive Bluetooth 4.0/WiFi PCIe Expansion Card
FREEBIE_VC: None
FREEBIE_VC2: None
GLASSES: None
HDD: 256 GB OCZ Agility 4 SATA-III 6.0Gb/s SSD - 420MB/s Read & 410MB/s Write (Single Drive)
HDD2: 2TB (2TBx1) Western Digital Caviar Black SATA-III 6.0Gb/s 64MB Cache 7200RPM HDD (Single Drive)
IEEE_CARD: None
IUSB: Built-in USB 2.0 Ports
KEYBOARD: AZZA Multimedia USB Gaming Keyboard
MB_SRT: None
MEMORY: 16GB (4GBx4) DDR3/1866MHz Dual Channel
MONITOR: None
MONITOR2: None
MONITOR3: None
MOTHERBOARD: * [CrossFireX/SLI] GIGABYTE GA-Z77X-UP4 TH Intel Z77 Chipset DDR3 ATX Mainboard w/ IRST, Lucid Virtu MVP, 2x Thunderbolt, Ultra Durable 5, 7.1 HD Audio, GbLAN, HDMI, 3x Gen3 PCIe x16, 3x PCIe x1 & 1 PCI (All Venom OC Certified)
MOUSE: AZZA Optical 1600dpi Gaming Mouse with Weight Adjustable Cartridge
NETWORK: Onboard Gigabit LAN Network
OS: Microsoft(R) Windows 7 Home Premium (64-bit Edition)
OVERCLOCK: Extreme OC (Extreme Overclock 20% or more)
POWERSUPPLY: 1,000 Watts - Cooler Master Silent Pro Gold 80 Plus Power Supply ( 80 Plus Gold)
SOUND: HIGH DEFINITION ON-BOARD 7.1 AUDIO
SPEAKERS: None
TABLET: None
TEMP: None
TUNING: * Intel(R) Core™ i5-3570K Performance Tuning Protection Plan by Intel
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO: AMD Radeon HD 7970 3GB 16X PCIe 3.0 Video Card (Major Brand Powered by AMD)
VIDEO2: None
VIDEO3: None
WNC: None
BLUETOOTH: None
CASUPGRADE: None
CD2: None
ENGRAVING: None
FA_HDD: None
FLASHMEDIA: None
FREEBIE_VC: None
FREEBIE_VC2: None
GLASSES: None
IEEE_CARD: None
MB_SRT: None
MONITOR: None
MONITOR2: None
MONITOR3: None
SPEAKERS: None
TABLET: None
TEMP: None
TVRC: None
USB: None
USBFLASH: None
USBHD: None
USBX: None
VIDEO2: None
VIDEO3: None
WNC: None
