1 1440p monitor and 2 1080p monitors with 1070?
lilj0unior
61
Can I run triple monitors with a 1070? The main monitor will be 1440p at 75hz, the second monitor is 1080p at 90hz herts, and the third is 1080p at 60hz. I'll only be using the 1440p monitor for gaming while the other 2 for media consumption. Will the 1070 be able to run all three at once while playing games? Like having chrome open on 1 monitor, netflix on the other, and for exxample bioshock or CS on my main monitor?
Also how well would a 1060 run this triple monitor setup?
a 1060 would struggle to hold its own on a single 1440p monitor by itself @ 60, though it will do it. A 1070 on the other hand works very nicely for 1440p. If all you intend on doing with the other two monitors is watching movies and browsing the web, your graphics card won't make a large difference. The difference would still be there obviously, so if you need locked 75 FPS @ 1440, definitely stick with the 1070.
