I am planing to Purchase these
Modem:
https://www.amazon.com/dp/B01N6SKK1G/ref=psdc_284715_t1_B0723599RQ
Router:
https://www.amazon.com/Tri-band-AiProtection-Accelerator-Compatible-GT-AC5300/dp/B071DPCKQ6/ref=sr_1_3?s=electronics&ie=UTF8&qid=1529905567&sr=1-3&keywords=asus+rog+router&dpID=51BxFVHLBXL&preST=_SY300_QL70_&dpSrc=srch
Switches:
https://www.amazon.com/gp/product/B00K4DS5KU/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Cat7 Cables:
https://www.amazon.com/gp/product/B00GK6KCS8/ref=ox_sc_act_title_5?smid=A2FI1E57JSSMJ2&psc=1
I know this is overkill by a ton for my personal Business, Don't care about that. I want to know if my idea will work.
I want the Modem connected to the Router Obviously, then 2 lines from the router running to major areas of my place. Both of these will be connected to a Managed Switch. Then from each Managed Switch the devices in the local area of each managed switch will be connected.
1) Will I be able to still control both managed switches, and configure the traffic priority properly?
2) Will everything work without an issue assuming proper setup.
3) Would I have to configure the QOS on both switches, or Just the Router?
4) Should I be using Unmanaged Switches Instead, and using the Routers QOS?
In which case I would be using this Switch:
https://www.amazon.com/gp/product/B00A121WN6/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&th=1
Thanks for your help!
Modem:
Router:
Switches:
Cat7 Cables:
