100% Disk Usage Problem
Byerrs
Commendable
Dec 12, 2016
5
I have went through every solution to try and fix the problem. It seems to be fine in till i open an application like Steam or Battle.net. At first I thought it was my new graphic card but it is still happening after i put my old one back in.
Any suggestions would be helpful, thank you.
Edit: even after trying this " http://www.tomshardware.com/faq/id-3267507/fix-100-disc-usage-system-service.html " My "System' and or 'Windows Modules Installer...' seems to be causing the problem. It is often using the most of the disk
