100w tpd cooler for a 125w cpu
Do you now have a cooler? If so, what is the problem?
AMD processors tend to run hotter than Intel and need very good cooling or they will slw down or shut off.
I would dismiss the first cooler, it is a downdraft type similar to stock coolers that are not very effective.
The second is better, it is a tower type but it also has a small ineffective 92mm fan.
Plus, it will spin up and get noisy under load.
Look for a tower type cooler with a 120mm or larger fan.
Cooler: ARCTIC AC Alpine 64 Plus ( https://www.pcgarage.ro/coolere/arctic-cooling/alpine-64-plus/ )
OR
ID-Cooling SE-902X ( https://www.pcgarage.ro/coolere/id-cooling/se-902x/ )
i dont know which one is better
Cpu: Amd phenom ii x4 965 BE
and an ordinary case
I do, a stock amd fan that in full load is noisy and also too high temperature, i will try to find a cooler with 120mm fan or wait for the second one to come available.
The second cooler you listed also has a noisy 92mm fan.
As a temporary measure, take your case covers off and see how much that helps.
i did, between 40-60 degrees. I found this one and i think it's ok for a moment. DeepCool GAMMAXX 200T 120 mm fan
http://www.deepcool.com/product/cpucooler/2015-09/7_4054.shtml . If it's good i will close this topic
in future i will change the case and buy other case fans aswell, thanks for the advice and for your patience with me, have a nice day
