Companies have been trying this tech for many years now, and it never makes it to market. The issues they always run into is output power restrictions, and interruptions when whenever anything crosses the beam.
I with they would have continued developing 802.11ad WiFi instead, but tune it for even higher speeds at even shorter ranges. One benefit at the time was effectively 2.5Gbe like performance over WiFi at a time when other standards were struggling to do 800mbps real world throughput (basically since many routers at the time that offered 802.11ad had only 1GbE ports, you need to download content simultaneously from 3 wired clients, but you could get well over 2Gbps without much issue.
Imagine if they continued developing the 60GHz band with more modern enhancements such as higher QAM modes and other improvements. They could probably get a 10+gigabit connection for devices within around 10ft of the AP, which could be useful for laptops, e.g., imagine you have a device set up where once in close range to the 802.11ad AP, it switches over and then begins backing up the data on the laptop. Or utilize it in a smartphone where when charging and close to the 802.11ad AP, it quickly backs up all data on the device to the user's NAS.
I currently do that now with foldersync pro. though the process would be so much faster with even faster WiFi.
