So i found a stable overclock for my palit 1050ti stormx without a 6pin connector i got +235 on core(1800-1911 mhz) and +950 on memory (4554 mhz) iwithout raising any voltages nothing just memory and core clocks all of that without a 6pin power connector and it seems the card protect itself from reaching over 74.8w so im safe from any bad scenario do you think this is ok? i had valley stress test running for 15 minutes and no crashes no artifacts nothing temps were between 64-65 and i also did a benchmark and those are the results below (photo)
do you belieive my card will break in the future even if it kinda stable and no voltage is raised and temp is okay?
results from benchmark extreme HD
http://imgur.com/a/9vvMC
