So I've been reading for a while already about this topic, Screen size vs Resolution and when does it matter?
However, no thread seems to fit the answer I'm looking for
I've had a 1366x768 monitor for a while, problem is that I just recebtly got a GTX 1060 6GB graphics card that doesn't support VGA.
Within my budget I also had planned to buy a new screen as well and I was wondering which option would be better, to buy a bigger screen with less resolution or to buy a smaller screen with higher resolution.
For example, I see a 32" TV but with a 1366x768 resolution, on the other hand, I see a 22" monitor with 1920x1080 resolution
I would be using it for both gaming and watching movies no more than 4 feet away
Is having a bigger screen worth it even if the resolution is smaller?
Is a smaller screen going to bereally rough to watch movies on?
And more importantly, at least for me, which would affect the performance more?
