1080p Video Editing/post processing System Build; What do I need to add/remove?
pwfdrinker
Commendable
Aug 3, 2016
6
I apologize I was tired and forgot to mention that I have a fully built computer with these parts below. I forgot to include the OS and RAM. I also forgot to mention that I'm trying to learn how to do video post production. If I could I would keep many of these parts in my build but if I need to change them let me know.
The Current Build:
  • Case: NZXT S340 (white)
    Motherboard - MSI Z170A Krait Gaming
    CPU: Intel I5-6600(non-K) 3.3GHz(3.9GHz Boost)
    GPU: XFX Radeon R9 390 Double Dissipation 8GB Vram OC(1050MHz / 1600MHz memory)
    SSD: 120GB Samsung EVO 850 (OS drive)
    HDD: Western Digital - WD10EZEX 1TB 7200rpm
    Monitor: Asus VX279Q 1920x1080p (displayport)
    RAM: 4 x 4GB Crucial Memory 2133Mhz (16GB)
    OS: Microsoft Windows 10 Retail 64-bit
    PSU: EVGA SuperNOVA G2 750W 80+ Gold Certified
I'm not familiar with video editing or it's requirements but I intend to use Adobe Premiere video editing software to practice and "master" any editing skills I need to learn. I'm an absolute beginner to video software and all the associated lingo. If you could include a website where I can learn about formats and whatever else I'd appreciate it.
You won't get much improvement without spending a hell of a lot more money. If the system works for you now, stick to it. Eventually you'll want to upgrade the storage though, I would highly suggest 2x 2-4TB disks in RAID1 (and a third in external enclosure connected only for backup) and a 500GB SSD for scratch/cache/current projects. Total cost will be about the same as an upgrade to a i7 6700K...
1) You need a power supply. I would recommend a EVGA G2 650 or RM650x minimum for that system
2) If you are only doing it for editing, throw away the 390 and upgrade to a i7 6700
3) If you aren't using K chips, no sense in getting the z170, go for an h170
4) You'll want more than 1TB storage
5) You need an OS!
6) You need RAM!
Hell, scrap your entire build idea and get this:
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($298.99 @ SuperBiiz)
Motherboard: Gigabyte GA-H170-GAMING 3 ATX LGA1151 Motherboard ($87.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2666 Memory ($62.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($89.89 @ OutletPC)
Storage: Hitachi Ultrastar 7K3000 2TB 3.5" 7200RPM Internal Hard Drive ($69.00 @ Amazon)
Video Card: MSI GeForce GTX 950 2GB Video Card ($129.99 @ Newegg)
Case: Corsair 100R Silent ATX Mid Tower Case ($59.99 @ Newegg)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply ($79.99 @ SuperBiiz)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($89.00 @ B&H)
Total: $967.82
Generated by PCPartPicker 2016-08-03 00:43 EDT-0400
As for learning, take a look at http://nofilmschool.com/2012/07/69-free-tutorial-videos-adobe-premiere-pro , it's a bit old, but Premiere Pro hasn't changed that much in the last few years.
I apologize I forgot to mention that I already have a complete system currently. I meant to ask about what might I need to change or add to my build for video post processing. My goal is to work with films and videos in the post processing phase of production. I just need to know where to start per se in regards to hardware and software.
You won't get much improvement without spending a hell of a lot more money. If the system works for you now, stick to it. Eventually you'll want to upgrade the storage though, I would highly suggest 2x 2-4TB disks in RAID1 (and a third in external enclosure connected only for backup) and a 500GB SSD for scratch/cache/current projects. Total cost will be about the same as an upgrade to a i7 6700K, but may actually save you more time in the long run
I appreciate the information. I definitely want to upgrade to an i7-6700 since it has high clocks and hyper threading. I am still not sure if my current build will be enough to do this work. I'll try and get the new CPU and setup the raid order you specified. Thanks!
Even with higher clocks and HT, the 6700 will only be 30-50% faster during encoding, and basically the same performance at all other times. If you plan your encodings during times you aren't using the computer (sleep, eating, etc), then there is basically no reason to go with the 6700k
