B Bgordy2013 Honorable Jan 30, 2014 21 0 10,510 Feb 14, 2014 #1 Looking for a case fan to add to my PC, I want one that looks cool with blue LEDs and also has a thermometer to keep it quiet. I need molex power because that is the only fan connector I have left. Thanks, Bgordy2013
Solution lxgoldsmith Feb 14, 2014 Here's one - http://www.newegg.com/Product/Product.aspx?gclid=CISEy-K5zLwCFWoV7AodwGsAMQ&Item=N82E16835214044&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Case+Fans-_-N82E16835214044&ef_id=Uv1kaQAAAcjGsxkz:20140214202545:s
lxgoldsmith Distinguished Sep 25, 2012 1,095 1 19,465 Feb 14, 2014 Solution #2 Here's one - http://www.newegg.com/Product/Product.aspx?gclid=CISEy-K5zLwCFWoV7AodwGsAMQ&Item=N82E16835214044&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-Case+Fans-_-N82E16835214044&ef_id=Uv1kaQAAAcjGsxkz:20140214202545:s Upvote 0 Downvote Solution
B Bgordy2013 Honorable Jan 30, 2014 21 0 10,510 Feb 14, 2014 #3 I looked at that one earlier, are you sure that is molex powered? Thanks for the reply! Upvote 0 Downvote
lxgoldsmith Distinguished Sep 25, 2012 1,095 1 19,465 Feb 14, 2014 #4 yes, it has a 3 pin connector, which is not pwm, so it must have its own thermal sensor Upvote 0 Downvote
