Hello, first post here! Anyways, I just upgraded from my old Antec 1200 case into a new Thermaltake F31 case. I had my friend over to help me and everything turned out nicely, but as neither of us had done anything like this before, I am unsure if the current fan setup is ideal.
Currently, I have:
1x 120mm intake fan in the front of the case
1x 120mm exhaust fan in the back of the case
1x 120mm intake radiator fan, connected to a radiator, attatched to the top of the case
And then there's the PSU and GPU fans of course, but those are fine as it is I think.
My question is, is this an okay setup, and should the radiator fan maybe be an exhaust instead of an intake fan? I haven't had any problems with heat so far (at least speedfan is repporting okay results), but I tried to look this up and I wasn't sure if I had it right.
I was also wondering if it would be advised to maybe move the radiator fan to the front of the case, above the intake fan (as you can see in my image, there is a lot of space). I thought this would maybe help with some noise, but maybe it is a bad idea? Does anyone know if this will negatively impact my CPU temperature?
To sum it up: Does my computer look okay? Should I move the radiator fan to the front of the case? Or should I keep it the way it is, and get another intake fan in the front? Thank you!
picture of the computer:
^http://i.imgur.com/OLEjLDj.jpg
Currently, I have:
