Ok so yes overkill on fans and RGB I KNOW! Setup: three front intake fans, three bottom intake fans, 3 RAD intake fans at side of case, 3 top fans outtake and 1 rear fan outtake. I’m in the process of installing everything and am trying to think ahead for wiring it all up. I’m trying to figure out how to wire up the 13th fan. My brain feels like mush so I‘m asking here.
The commander pro has 2 usb slots which are being taken up by the commander core ( that came with the AIO)and one of the lighting nodes that came with one of the 3 packs of fans. Both of those devices have rgb slots for 6 fans each. I figured the rear fan pwr can be plugged straight into the MOBO but where does it’s rgb go?
I have 3 more lighting nodes but where would I plug their USB cords in? Should I buy an internal usb splitter? If so should the splitter be plugged into commander pro or the MOBO? I feel like I’m missing something here! Any advice is welcome!
Oh also how exactly do you use the temperature sensor cables that come with commander pro? Do you just string them in different places in the case or some place specific?
ALL FANS ARE CORSAIR iCUE QL120s
Parts list if you’re curious: https://pcpartpicker.com/user/Twistfaria/saved/hNpnt6
