[SOLVED] 144hz problem
luichi
Commendable
Oct 19, 2016
17
I just acquired a 2070 card, and sadly discovered that I can't get 144hz with my benq xl2411.
With this monitor I can only get to 144hz with a DVI-D cable, the problem is that the graphic card doesn't have a DVI port (only DP and HDMI) and the monitor doesn't have a DP port. So I can only connect each other with HDMI. Is it posible to get to 144hz using an adapter? Or am I just screwed and on need of a new monitor?
Thanks for your answers.
Active adapters are your only way.
Unfortunately, the required adapters are going to run you >$50 USD.
https://www.amazon.com/Dell-BIZLINK...ascsubtag=tomshardware-1412880091663036308-20
Reactions: luichi
Thanks for you answer, do you think that it would be better to just sell my monitor and buy a new one? It's like in the first day.
Looks like they sell used, for ~$150.
Tough call, but looks like you could pick up something fairly comparable (with DisplayPort) for around ~$170.
Cheaper to sell/buy for a net spent of roughly $20 opposed to $50+ on an adapter that would work..... but entirely your call.
