160mm CPU Cooler - 159mm CPU cooler slot.
wasshup
75
Hi,
I have SilentiumPC Regnum RG2Wand I want to buy Noctua NH-D14 because with cooler that I have now my i7 7700k overheating. Some sites have in specs max height 159mm some 160mm. Do you thing that this cooler with with this case ?
Thank you
Michal
Id say the noctua will fit , silentium spec cooler height at 160mm anyway (not 159mm)
Id be more concerned with ram clearance than anything else , the noctua can hit 2 slots on a lot of boards & if you dont have low height ram then its not going to fit.
Yes it will fit go for it
my case has a max height of 169 and my CPU cooler is 172mm i took the risk and bought it and it fitted properly:)
Yes, if you can just for info :) I'll check. Today I should get the cooler so I can post info about mine
