16gb ddr3 system memory (2 dimm) for intel(r) core(tm)2 duo processor t9600 (2 8
gleen
8
I like to upgrade my RAM from 4GB to 16GB ,below are my configuration detail.
Genuine Windows Vista Ultimate with Service Pack 1 (64-bit)
- Intel(R) Core(TM)2 Duo Processor T9600 (2.80GHz)
- 4GB DDR3 System Memory (2 Dimm) - For 1GB NVIDIA GeForce 9600M GT graphics.
Any help greatly appericiated!
thanks,
Gleen
The info I can find about C2D-T9600 says it uses DDR2, not DDR3.
The largest DDR2 SO-DIMMs I can find are 4GB each so it seems you won't be able to go beyond 8GB with two slots.
If you really want 16GB, you will have to upgrade your laptop to something that supports DDR3.
There were some "4" series chipset boards that did support DDR 3 at 800/1066 but it is really up the motherboard/laptop manufacturer.
http://www.intel.com/Assets/PDF/datasheet/320122.pdf (Page 13)
Christian Wood
Intel Enthusiast Team
Mine is personlized one ,here is below details :
HP HDX X18T-1200 CTO Premium Notebook PC
- tHP HDX18t Premium Series Notebook PC
- Upgrade to Genuine Windows Vista Ultimate with Service Pack 1 (64-bit)
- 500GB 5400RPM SATA Dual Hard Drive (250GB x 2) with HP ProtectSmart Hard Drive Protection
- 1GB NVIDIA GeForce 9600M GT
- 18.4" diagonal High Definition HP Ultra BrightView Infinity Display (1920x1080p)
- Blu-Ray +/-R/RW with SuperMulti
- Webcam + Fingerprint Reader with HP Imprint Finish (Fluid)
- Intel Next-Gen Wireless-N Mini-card
- HP Integrated HDTV Hybrid Tuner
- HP Color Matching Keyboard
- 8 Cell Lithium Ion Battery
- Mobile Stereo Earbud Headphones (1 pair)
- System Recovery DVD with Genuine Windows Vista Ultimate (64-bit)
i have to check the mother piece if needed.
Contacted HP :They don't have 16GB ,so they have the below one :HP 4GB DDR3-1333 Laptop PC Memory
QF275AA#ABA
They are bunch of them online.
Can you recomment me the best one- frys.com or any place.
Thanks in advance
I also see this product :FRYS.com #6932057 $ 139.99
CORSAIR 16GB (2 x 8G) 204-Pin DDR3 SO-DIMM DDR3 1333MHz Laptop Memory Model CMSO16GX3M2A1333C9
Mfr: Corsair Model: CMSO16GX3M2A1333C9
what would go wrong if i go with 16GB one.I have given more details about 16GB below.For some reason my laptop does not recongize.Anyway i am going to backup my data.
Cas Latency: 9
Timing: 9-9-9-24
Voltage: 1.5V
Multi-channel Kit: Dual Channel Kit
Specification Value
Memory Category: Laptop
Memory Type: DDR3
Memory Speed: PC3-10600 / 1333MHz
ECC: No
ECC Registered: No
Total Memory Size: 8
Memory Channels: Dual
Memory Socket: SODIMM
Pins: 204
Voltage: 1.5
Thanks in advance.
Same-type DIMMs are SUPPOSED to be fully interchangeable but some combinations of motherboards, BIOS, SPD chips, DIMM PCBs and DRAM chips have quirks that prevent them from working together.
There are millions of possible laptop + DIMM combinations that should work but laptop manufacturers only certify a very small subset (often home-brand) and DIMM manufacturers only verify each of their modules with a small subset of all laptops.
Most DIMMs should work in most same-type laptops but only a small subset of combinations are certified. Same goes for regular PC DIMMs, most DIMMs should work fine even if they are not on the motherboard/CPU manufacturer's approved list. Those on the list are simply those the manufacturers have specifically tested themselves and can guarantee that it will work.
I installed 16GB on my laptop ,i see a blank screen ,i tried couple of time with no luck ,then i installed my old one and my welcome screen came up as normal.I am not sure what would be the problem 16GB.
MY motherboard does not support 16GB from my experience past couple of days.I just add 8GB(2x4) and it worked well.I am not seeing any improvement from 4GB to 8GB.
Any comment
ThankYou
Next time if i buy a Laptop.I will look for 4GB for video Card and 16GB RAM.I am not sure it exit now.May be future laptop motherboard can support it.
Thankyou
sorry bud, but your pc only supports 8 gb. 4 gb per slot and 2 slots. check this link for more info http://www.crucial.com/store/listparts.aspx?model=HP%20HDX%20X18T-1200%20CTO&Cat=RAM
our HP HDX X18T-1200 CTO System Specs
System specs as shipped by the manufacturer.
Scan your system to view your specific system configuration.
Memory:
DDR2 PC2-6400
Memory Type: DDR2 PC2-6400, DDR2 (non-ECC)
Maximum Memory: 8GB
Slots: 2
Each memory slot can hold DDR2 PC2-6400 with a maximum of 4GB per slot.*
*Not to exceed manufacturer supported memory.
