Your English is fine
No need to apologize.
Depending on your case, you may be able to, over time get better cooling by removing the 180mm and putting in several smaller fans. I don't know what case you have, so that's something to investigate. Most cases with a big side fan can handle several smaller fans.
Are you opposed to liquid cooling? They're usually more compact and there are some AIOs that are in a similar price range to the 212 Evo. There are also many very good smaller air units. I once used a Zalman CNPS 8900. It was quite small. I also wasn't pleased with it's contact to my CPU and the temps weren't as good as I hoped. It had direct contact heatpipes and so couldn't be sanded to get better contact. But, long story short: there's lots of options for smaller coolers that will fall into the same price range as the 212 EVO.
To help us get you some other options, I ask two questions. What case do you have and what country are you from?
