Question 1920x1080 resolution missing from nvidia control panel
Brian4222
19
Hello, I'm missing 1920x1080 resolution from my Nvidia Control Panel under "PC" section which you can see here https://prnt.sc/GfMHkvHoA0On
The reason why I can't use the one under "ULTRA HD, HD, SD" section is because it's causing fps drops, can someone help?
full system spec? what the monitor? what connection? using adapter?
Corsair TX650
GTX 980 Ti
Ryzen 5 2600
B450 TOMAHAWK
2x8 GB RAM DDR4
250 gb ssd
1tb hdd
1st monitor is AOC 144 hz - display port
2nd monitor is 21 inch samsung led monitor - hdmi
1920x1080 resolution is missing on my second monitor and it disappeared after I factory restarted my PC.
