1st Build, custom cable information.
Smiddy35
Commendable
Jul 23, 2016
14
I'm looking to get some custom cables, and this is my first time building a PC. I've come across a lot of cable modding sites. I'm wondering what cables I'll need. I've been looking at cable mods, but welcome all info.
My question? What cables will I need? I don't want to just buy every cable they have. Also they have paracord or nylon options. Any help would be greatly appreciated. This is the build I'm going with. Thanks
http://pcpartpicker.com/user/Smiddy35/saved/Nk3zK8
You'll need:
1x 24pin ATX
1x 4+4pin EPS
2x 6+2pin PCIe (4 if you plan to add a second card)
2x SATA power (I recommend single-plug SATA power because going with dual plug would be a little difficult with SSD mounts)
Optional 2x SATA data (if you want them sleeved instead of regular black)
Recommend adding the following cable combs:
1 for 24pin
2 for 4+4pin
4 for 6+2pin (or 8 combs for 4 cables)
You'll need:
1x 24pin ATX
1x 4+4pin EPS
1 for 24pin
2 for 4+4pin
