[SOLVED] 1st time build. Is everything ok with these parts together? 5600g
Aug 22, 2021
https://pcpartpicker.com/list/36n6Gq
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor
Motherboard: Gigabyte B550 AORUS ELITE ATX AM4 Motherboard
Memory: Crucial Ballistix 16 GB (2 x 8 GB) DDR4-3600 CL16 Memory
Storage: ADATA XPG GAMMIX S41 256 GB M.2-2280 NVME Solid State Drive
Power Supply: Corsair TXM Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply
Wanted to double-check with you guys if these parts would work nicely together. This is my 1st build so suggestions or tips would be appreciated, thank you!
- The idea of a 650w power supply is to eventually get a GPU, no idea when tho. The goal is to get a 3060ti or a 3070
Looks like a good build to me. The 5600G should provide 'adequate' gaming until you can...
Looks like a good build to me. The 5600G should provide 'adequate' gaming until you can find an affordable discrete GPU.
Do you have another drive to use for data storage? that 256Gb NVME will fill up pretty fast with only a few modern games and the OS.
Lastly: you might check that the motherboard comes with a BIOS for the 5600G CPU. It has a Q-Flash feature but it's less stress inducing knowing it's ready to go as soon as it's built.
