1tb seagate hard drive
jloots
6
hi guys,
i have a problem with my hard drive. when i disconnect it from my pc everything runs fine, but when i connect it to my pc it gives me problems. just before the windows plash screen i get a message that says, "GEMZP is compressed press ctrl+alt+del to restart". i have no idea what it means. not even microsoft can help me and i cant even find such a thing on google.
urgently need help with this. all my document and work is stored on this hard drive.
That's not a good sign as it usually means the drive has already failed.
"This is a hard drive I use only for storage"
That doesn't invalidate what I said earlier about keeping second copies of everything on a second storage drive. I keep four backups of all my stuff on four externals & when one of them fails I replace it and transfer backups to it straight away from one of the others.
Your only hope of retrieving the data now is to send the drive to a data recovery specialist, but it won't be cheap because it's a service that caters mainly for businesses and large corporations.
Well you should never rely on just a single hard drive for file storage, you need at least two so you have at least one backup of everything.
Test it with SeaTools: http://www.seagate.com/gb/en/support/downloads/seatools/seatools-win-master/
If Windows won't start with that drive connected, buy an external enclosure for it so you can plug it in to a USB port after Windows has loaded, then test it.
