Old setup
Main PC (wireless enabled)
Coax downstairs wall outlet to cable modem
Ethernet router to Dell PC (hardwired)
USB PC to Epson printer/fax
Backup PC (no wireless)
Coax upstairs wall outlet to latest Comcast rental router
Phone base with 5 satellite units wired to router through the printer for FAX.
USB PC to Epson printer (same model as the other one)
Laptop and visiting extended family members are connected Wi-Fi as our EMC security system and its smart phone app.
What happened:
Main PC quit due to bad internal HD. Nearly decade old backup PC was having non-fatal internal HD problems but it was still working when we scrapped it. We bought a new Dell PC. We used True Image to restore our files and apps from an inoperative PC backup. Everything still worked fine with the wired PC and the new one.
And Then:
I bought a new identical HD and swapped it out for the defective one. We True Image restored it to its last backup before it quit. I have restored two PCs from the same Backup before without incident. (Problem now?) Our cable modem is no longer supported by Comcast because it is maxed out on speed. My wife does like the fact that if the rented router fails we are without our phone until we swap it out at our Xfinity store, rewire it, and face any activation issues that occur. We are both older than 75 and cannot always go out. So I bought an Xfinity supported cable modem with phone connection. The one without the phone jack is still a good backup if we need to hook it back up.
What we wanted
Two independent Ethernet wired systems with the phone base unit hooked up to new modem. We keep the rented router for its Wi-Fi but would prefer to connect it to the PC via Ethernet.
What works so far
Router with only the Coax attached for main PC. The way it works now I think it could be hooked up to any COAX outlet in the house not just the one closest to the PC. Both printers are USB hard wired. Internet by Wi-Fi on all of our devices. Ethernet connections can be set up but they always get dropped somehow. The Network list still sees the Ethernet connection but it says no internet. When we only had one wireless enabled PC our Network name was the same for Wi-Fi and Ethernet and you had to click on the network listing to actually see which one you are using.
CAN WE GET EVERYTHING ETHERNET WIRED MODEM TO PC OR MUST WE STICK WITH WI-FI?
A Comcast chat agent told me they only support one modem but he also told me I couldn't buy Xfinity equipment. Yet Comcast referred me to Amazon to buy the new one which is badged Xfinity.
What happened:
And Then:
What we wanted
What works so far
