fastracer Sep 10, 2020 1 0 10 Sep 10, 2020 #1 How do I connect 2 pwm fans to a 4 pin sys_fan on mobo, I have a splitter, do I put them both on the splitter and hook it up to the 4-pin on the mobo or is there a better/specific way to do it?
Solution Karadjgne Sep 10, 2020 Nope. It's not really rocket science, your first guess was correct. Splitter looks like a Y. The fans go on the split, the stem goes to the mobo.
Karadjgne Titan Ambassador Dec 26, 2012 30,750 4,552 142,790 Sep 10, 2020 Solution #2 Nope. It's not really rocket science, your first guess was correct. Splitter looks like a Y. The fans go on the split, the stem goes to the mobo. Reactions: freyjamhanderson and fastracer Upvote 0 Downvote Solution
