View: https://imgur.com/a/thXGlp6
^ Link to show you the 2 different kits of ram
Greeting,
I just bought a prebuilt PC, it came with 16gb of Team T-Force Delta DDR4 3200mhz ram with timing of CL-16-18-18-38.
I then purchased another kit of 16gb of the same ram rated 3200mhz and it also has the same timing, as shown in the picture above.
When I put the extra ram in my PC, it reads it and I have 32gbs of ram recognized, but my ram is then running at 2400mhz speed.
When I go into my BIOS which I also updated, I turn on XMP profile and it shows it will run the ram at 3200mhz but then my PC does not boot.
Is there anything I can try before I send this ram back and just buy a 32gb one kit of ram?
Thanks!
My parts:
MSI Z590 Pro Wifi Motherboard which I flashed to its latest BIOS
EVGA RTX 3080
Intel i9-11900k
Greeting,
Thanks!
My parts:
EVGA RTX 3080
Intel i9-11900k
