Question 2018 Pc build, are these temps exceptionally low, or normal for these specs?
Nov 21, 2020
7
Hello, as the title implies, I simply want some feedback on if I have adequate temperatures, or if they're very low great ambient temps, or just average. These are idle temps after being at work all day.
Pc was built in 2018 by me with following major components:
Corsair x570 crystal series case
Aorus gaming 7 mobo
I7 8700k cpu on 4.8ghz oc
Evga gaming sc2 ftw3 gtx 1080ti
Corsair 115i pro rgb cpu cooler
artic mx-4 thermal paste
I have the cpu cooler radiator front mounted with the tubes coming down from the mobo to the bottom of the radiator to avoid air bubbles and for optimal flow. Fans should be in intake position (i do believe). I have 2 120mm rgb corsair fans on the top of the case exhausting air out the top. Lastly, I have another 120mm corsair fan in the rear of the case, exhausting air out the back as well.
hw info screenshot here, wouldn't let me post picture from link via post creator buttons.
View: https://imgur.com/Ste1hT1
I've heard that the i7 8700k ran hot as hell more often than not, so I was just curious for feedback on what others considered normal for a setup of this caliber and if my temps were higher or lower than normal.
