220-watt PSU running a GeForce GT 630 in an Emachines EL1352g-41w?
Craig M
118
I have an Emachines EL1352g-41w ( http://www.newegg.com/Product/Product.aspx?Item=N82E16883114102 Link for all specs if needed ) and I was researching to see if I could use the Geforce GT 630 for this computer. I checked the usual wattage needed for each computer part and added them all up. I figured I would also disconnect my dvd drive to stop power from going to it as an added bonus (probably wouldn't need to do that, but yeah lol). Anyways, I came up with the PC using around 176 watts with everything including this graphics card. I will show you how I arrived at that number. Just clearing up now that I like the price range of this graphics card and I like how it performs from what I've read about it. I know about the 750 ti and other cards, but I'm not looking to spend a bunch of money on this lol I must also add that I am perfectly content with playing games at their lowest settings. Below is the PC wattage use for parts in my computer (some numbers are elevated to allow for error).
PC wattage use
AMD Athlon II X2 220 65-watts ( http://www.cpu-world.com/CPUs/K10/AMD-Athlon%20II%20X2%20220%20-%20ADX220OCK22GM.html )
Motherboard 40-watts going by the higher number for the motherboard ( http://www.buildcomputers.net/power-consumption-of-pc-components.html )
RAM-6-watts ddr3 are said to be around 2-3 watts each ( http://www.buildcomputers.net/power-consumption-of-pc-components.html )
GeForce GT 630 50-watts ( http://gaminginsideinfo.blogspot.com/2013/10/best-low-power-graphics-card-for-gaming.html )
Hard Drive 9-watts ( http://www.buildcomputers.net/power-consumption-of-pc-components.html )
Case fan 6-watts I just went with the highest listed one for this at 6-watts lol Whatever is in my pc, it keeps it very cool no matter what I do lol ( http://www.buildcomputers.net/power-consumption-of-pc-components.html )
DVD drive Unplugged and not in use
I've heard stories about how people were using PSUs (220 and even lower) with good results on certain cards that were said to require 300-400-watts. Is there really any reason as to why this card wouldn't work in this PC? At the very least, would it be a decent enough upgrade for me to play my League Of Legends game without any lag? If you see errors in my research, please feel free to correct me as I'm not that knowledgeable about these things and it's late lol Thanks for your time and any help with this.
It seems you've researched your system power usage pretty well. You should know that sustained loads at close to maximum capacity is not a good idea, even for a high quality PSU. An OEM unit, which are generally made from cheap low quality parts, will simply fail under the stress eventually. The question is, when it fails, will it go out with a whimper or a bang? Proceed at your own risk, knowing the potential consequences.
Thank you. I may consider getting the first one in what you listed. I may try to get it, a decent CPU and attempt to use the gtx 560 in my old computer that I am trying to fix up to play some games on.
You lack overclock potential on that eMachine board but these would be a world better, no point in paying more than what this one cost your gains would be minimal without the ability to overclock.
AMD Athlon II X4 640 3 GHz Quad-Core Processor US $45.00
http://www.ebay.com/itm/AMD-Athlon-II-X4-640-3-GHz-Quad-Core-Processor-/331532736127?pt=LH_DefaultDomain_0&hash=item4d30e4167f
Motherboard replacement to allow Overclocking.
Combo
-Foxconn A88GMX AM3 Motherboard. $20
-Phenom II X4 945 Black Edition. $65
http://arstechnica.com/civis/viewtopic.php?f=12&t=1280247&sid=02b7b80044927f50ea21026bc740f0ae
I don't really want to overclock anything though. With the motherboard I have, I just wanted to upgrade with a decent amd quad core CPU, decent GPU (if gtx is actually dead and doesn't work), and upgrade power supply with the first one you suggested. I'm trying to keep price down to around 150-160 or so is possible. I've actually overclocked using this computer already with decent results on it (although like I said, I don't really want to OC if I get better parts for it). I feel like this will at least allow me to play many games on low settings/low display at the very least without lag and all lol
