You mean that 600w is enough? I don't get you :/
Yes it costs 120€+ and it's over 750w availables in my countryPost #22 you said, replied to me series is too expensive, assuming you meant RXm.
You mean BeQuiet! System Power 9 CM 600W 80 PLUS Bronze this one?Then get that, you'll be set for a long time, and upgrades.
I know but it's the double money from BeQuiet! System Power 9 CM 600W 80 PLUS Bronze and it's pain in a## 170€ which BeQuite costs only 60€ :/Perfect psu. Your pc wont consume anymore as before, just psu capacity is more if you upgrade more, + quality can't be beat with Rmx.
I see the reviews about the rmx 750w and it's worse like bad cable management and noise sometimesLook at warranty, warranty speaks for itself in terms of quality and how confident the company is with it. Rmx is 10yrs guaranteed, bronze be 3 maybe 5 yrs? I haven't looked at it but have a fair idea it be 3yrs. You won't go wrong with Corsair RMx long term.
What about bad reviews about cable management and noise even in idle ?
Just because a PSU is 750W doesn't mean it is going to pull 750W the entire time. The wattage number is just the amount of power it can covert from AC > DC. If your computer is only needing 50W that is all the PSU will draw. The RMx has higher efficiency which means it could save you money on power in the long run over a PSU with lower efficiency.I am going for Rxm 750w
I hope that I won't see any huge differences to the electricity bills 😁😁😁
The fan orientation depends on your case. If the PSU is top mounted, the fan should face the inside of your case.Love ya
Another question
Psu fan should facing upwards ⬆️
Or downward ⬇️ the floor?
